imx8mq_m4_TCM_hello_world.bin with Thud
4,761 次查看
francesco_giust
Release: Yocto-Thud ( kernel 4.19.35 )
Board: i.MX8MQ EVK
I am checking Thud release and I would test M4 example, but I have a problem.
When I try to load imx8mq_m4_TCM_hello_world.bin in u-boot, I get this message:
u-boot=> fatload mmc 1:1 0x7E0000 imx8mq_m4_TCM_hello_world.bin
** Reading file would overwrite reserved memory **
should I use another address ?
I already test on Yocto-Sumo and there it works fine.
Francesco Giusti
7 回复数
2,565 次查看
neuberfran
4,025 次查看
zach890
Have there been any updates to this issue? I'm running into this very same issue on the iMX7D chip. One day I was able to fatload to the TCM and now I can't fatload to any address without getting the reserved memory error.
Even if it's not a solution is there a way to figure out what already has the memory reserved?
4,213 次查看
fawad_nackvi
I am on a mx8m and I got the same issue. "Reading file would overwrite reserved memory" on 4.19.35_1.1.0. I did the following to load the TCM M4 program and it worked :
fatload mmc 1:1 0x48000000 imx8mm_m4_TCM_hello_world.bin
cp.b 0x48000000 0x7e0000 20000
bootaux 0x7e0000
4,212 次查看
CarlosCasillas
Hi Francesco,
Until now, the most recent Linux version included on the supported NXP BSP releases is L4.14.98, so 4.19.35 is not tested/validated yet.
In case of using other Linux versions, you could refer to the Community BSP:
FSL Community BSP
Hope this will be useful for you.
Best regards!
/Carlos
4,213 次查看
francesco_giust
Hi Carlos,
I do the same test with imx-yocto-L4.19.35_1.1.0 ( U-Boot 2019.04-4.19.35-1.1.0+g4d377539a1 ), but I get the same result:
u-boot=> fatload mmc 1:1 0x7e0000 imx8mq_m4_TCM_hello_world.bin
Should I use an other memory address ?
BR,
Francesco
4,213 次查看
mischo5500
Got same problem on L4.19.35_1.1.0 warrior on imx7sabre board for command:
=> fatload mmc 0:1 0x7F8000 imx7d_sabresd_m4_TCM_helloworld.bin
Did you solve it?
Thanks in advance.
