您好!
最近在调试摄像头模块,检查驱动已经正常和/dev下的video1设备连接,想测试下摄像头功能,请问imx8mq是否有相关调试程序,检测video的基本功能,显示图像。
谢谢!
pls refer to the application note as below:
https://www.nxp.com/webapp/sps/download/preDownload.jsp?render=true
有具体应用链接么?测试imx8mq上的v4l2摄像头框架的就行,谢谢
pls refer to the application note I sent to you, did you refer to this? let me send to you again
i.MX 8M Applications Processor | Arm® Cortex®-A53, Cortex-M4 | 4K display resolution | NXP
pls find "Quick Start Guide for MINISASTOCSI for i.MX 8M Evaluation Kit "
you also can download it from the link I sent to you from my first reply
