Hi ,
I have downloaded the https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/isp-imx-4.2.2.13.0.bin
chmod +x isp-imx-4.2.2.13.0.bin
./isp-imx-4.2.2.13.0.bin
I build the toolchain in yocto using:
bitbake meta-toolchain
./tmp/deploy/sdk/fsl-imx-wayland-glibc-x86_64-meta-toolchain-cortexa53-crypto-imx8mpevk-toolchain-5.10-hardknott.sh
and
source opt/fsl-imx-wayland/5.10-hardknott/environment-setup-cortexa53-crypto-poky-linux in a new terminal in isp-imx-4.2.2.13.0 directory
././build-all-isp.sh Debug Full
this build is failing halfway with error
can anyone help me to solve this,
thanks, mukesh
解決済! 解決策の投稿を見る。
i used the following sdk script instead of metatoolchains , and it worked
$ bitbake imx-image-multimedia -c populate_sdk
it created a file fsl-imx-wayland-glibc-x86_64-imx-image-multimedia-cortexa53-crypto-imx8mpevk-toolchain-5.10-hardknott.sh at tmp/deploy/sdk/
You need install libdrm-dev library in ubuntu
