We set i2c 4 frequency on imx8mp 100 khz frequency but when we measured frequency it's getting 96.7 khz.
on other i2c1,i2c2 and i2c3 it's perfectly generate 100 khz.
why 96.7KHz is measured frequency instead of 100KHz ?
Hi Ankit
reason may be that parent clock can not be divided evenly for producing exact 100KHz,
one can at information about clocks using clocks unit test and driver
https://source.codeaurora.org/external/imx/linux-imx/tree/drivers/clk/imx/clk-imx8mp.c?h=lf-5.10.y
We try run dump-clocks scripts not running successfully it's showing below logs,
root@imx8mp:/unit_tests/Power_Management# ./dump-clocks-dot.sh
---- Running < dump-clocks-dot.sh > test ----
deprecated!please check /sys/kernel/debug/clk/clk_summary for detailed info
root@imx8mp:/unit_tests/Power_Management# ./dump-clocks.sh
---- Running < dump-clocks.sh > test ----
