The code is modified as follows:
struct mxc_isi_fmt mxc_isi_out_formats[] = {
+.name = "SBGGR12",
+.fourcc = V4L2_PIX_FMT_SBGGR12,
+.depth = { 12 },
+.color = MXC_ISI_OUT_FMT_RAW16,
+.memplanes = 1,
+.colplanes = 1,
+.mbus_code = MEDIA_BUS_FMT_SBGGR12_1X12,
struct mxc_isi_fmt mxc_isi_src_formats[] = {
+ .name = "SBGGR12",
+ .fourcc = V4L2_PIX_FMT_SBGGR12,
+ .depth = { 12 },
+ .memplanes = 1,
+ .colplanes = 1,
struct mxc_isi_fmt *mxc_isi_get_src_fmt(struct v4l2_subdev_format *sd_fmt)
+else if(sd_fmt->format.code == MEDIA_BUS_FMT_SBGGR12_1X12)
+ index = 3;
+else
+ index = 0;
dts:
&i2c3 {
#address-cells = <1>;
#size-cells = <0>;
status = "okay";
mlx75027_mipi@57 {
assigned-clocks = <&clk IMX8MP_CLK_IPP_DO_CLKO2>;
assigned-clock-parents = <&clk IMX8MP_CLK_24M>;
assigned-clock-rates = <8000000>;
AVDD-supply = <®_3p3v>;
compatible = "mlx75027";
clock-names = "xclk";
csi_id = <0>;
DOVDD-supply = <®_3p3v>;
DVDD-supply = <®_3p3v>;
mclk = <8000000>;
mclk_source = <0>;
mipi_csi;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_gpio5>, <&pinctrl_gpio6>, <&pinctrl_gpio7>, <&pinctrl_gpio8>;
//pinctrl-0 = <&pinctrl_gpio5>, <&pinctrl_gpio6>;
trigger-gpios = <&gpio4 1 GPIO_ACTIVE_LOW>; /* Apalis GPIO4 trigger pin dahlia:SODIMM 222*/
rst-gpios = <&gpio1 7 GPIO_ACTIVE_HIGH>; /* Apalis GPIO1 reset pin dahlia:SODIMM 216*/
led-gpios = <&gpio1 8 GPIO_ACTIVE_LOW>; /* Apalis GPIO2 led pin dahlia:SODIMM 218*/
alert-gpios = <&gpio4 3 GPIO_ACTIVE_LOW>; /* Apalis GPIO3 temperature alert dahlia:SODIMM 2
20*/
PVDD-supply = <®_3p3v>;
reg = <0x57>;
camera_mipi_lanes = <4>;
status = "okay";
port {
mlx75027_ep: endpoint {
clock-lanes = <0>;
data-lanes = <1 2 3 4>;
remote-endpoint = <&mipi_csi0_ep>;
&isi_0 {
status = "okay";
cap_device {
status = "okay";
&mipi_csi_0 {
#size-cells = <0>;
/delete-property/virtual-channel;
status = "okay";
/* Camera 1 MIPI CSI-2 (CSIS0) */
port@0 {
reg = <0>;
mipi_csi0_ep: endpoint {
csis-hs-settle = <4>;
csis-clk-settle = <1>;
csis-wclk;
data-lanes = <4>;
remote-endpoint = <&mlx75027_ep>;
Using v4l2-ctl to capture images, no error will be prompted and no data will be obtained
It seems that the sensor is not connected
dump register info:
[ 36.514445] bypass csc
[ 36.523442] mxc-isi 32e00000.isi: ISI CHNLC register dump, isi0
[ 36.523447] mxc-isi 32e00000.isi: CHNL_CTRL[0x00]: e0000000
[ 36.523451] mxc-isi 32e00000.isi: CHNL_IMG_CTRL[0x04]: f000001
[ 36.523455] mxc-isi 32e00000.isi: CHNL_OUT_BUF_CTRL[0x08]: 7c707
[ 36.523459] mxc-isi 32e00000.isi: CHNL_IMG_CFG[0x0c]: 1e00280
[ 36.523463] mxc-isi 32e00000.isi: CHNL_IER[0x10]: 3cfc0000
[ 36.523467] mxc-isi 32e00000.isi: CHNL_STS[0x14]: 100
[ 36.523471] mxc-isi 32e00000.isi: CHNL_SCALE_FACTOR[0x18]: 10001000
[ 36.523475] mxc-isi 32e00000.isi: CHNL_SCALE_OFFSET[0x1c]: 00
[ 36.523479] mxc-isi 32e00000.isi: CHNL_CROP_ULC[0x20]: 00
[ 36.523482] mxc-isi 32e00000.isi: CHNL_CROP_LRC[0x24]: 00
[ 36.523486] mxc-isi 32e00000.isi: CHNL_CSC_COEFF0[0x28]: 00
[ 36.523490] mxc-isi 32e00000.isi: CHNL_CSC_COEFF1[0x2c]: 00
[ 36.523493] mxc-isi 32e00000.isi: CHNL_CSC_COEFF2[0x30]: 00
[ 36.523497] mxc-isi 32e00000.isi: CHNL_CSC_COEFF3[0x34]: 00
[ 36.523500] mxc-isi 32e00000.isi: CHNL_CSC_COEFF4[0x38]: 00
[ 36.523504] mxc-isi 32e00000.isi: CHNL_CSC_COEFF5[0x3c]: 00
[ 36.523508] mxc-isi 32e00000.isi: CHNL_ROI_0_ALPHA[0x40]: 00
[ 36.523511] mxc-isi 32e00000.isi: CHNL_ROI_0_ULC[0x44]: 00
[ 36.523515] mxc-isi 32e00000.isi: CHNL_ROI_0_LRC[0x48]: 00
[ 36.523519] mxc-isi 32e00000.isi: CHNL_ROI_1_ALPHA[0x4c]: 00
[ 36.523523] mxc-isi 32e00000.isi: CHNL_ROI_1_ULC[0x50]: 00
[ 36.523526] mxc-isi 32e00000.isi: CHNL_ROI_1_LRC[0x54]: 00
[ 36.523534] mxc-isi 32e00000.isi: CHNL_ROI_2_ALPHA[0x58]: 00
[ 36.523537] mxc-isi 32e00000.isi: CHNL_ROI_2_ULC[0x5c]: 00
[ 36.523541] mxc-isi 32e00000.isi: CHNL_ROI_2_LRC[0x60]: 00
[ 36.523545] mxc-isi 32e00000.isi: CHNL_ROI_3_ALPHA[0x64]: 00
[ 36.523548] mxc-isi 32e00000.isi: CHNL_ROI_3_ULC[0x68]: 00
[ 36.523552] mxc-isi 32e00000.isi: CHNL_ROI_3_LRC[0x6c]: 00
[ 36.523556] mxc-isi 32e00000.isi: CHNL_OUT_BUF1_ADDR_Y[0x70]: d2100000
[ 36.523559] mxc-isi 32e00000.isi: CHNL_OUT_BUF1_ADDR_U[0x74]: 00
[ 36.523563] mxc-isi 32e00000.isi: CHNL_OUT_BUF1_ADDR_V[0x78]: 00
[ 36.523567] mxc-isi 32e00000.isi: CHNL_OUT_BUF_PITCH[0x7c]: 500
[ 36.523570] mxc-isi 32e00000.isi: CHNL_IN_BUF_ADDR[0x80]: 00
[ 36.523574] mxc-isi 32e00000.isi: CHNL_IN_BUF_PITCH[0x84]: 00
[ 36.523578] mxc-isi 32e00000.isi: CHNL_MEM_RD_CTRL[0x88]: 00
[ 36.523636] mxc-isi 32e00000.isi: CHNL_OUT_BUF2_ADDR_Y[0x8c]: d0100000
[ 36.523643] mxc-isi 32e00000.isi: CHNL_OUT_BUF2_ADDR_U[0x90]: 00
[ 36.523648] mxc-isi 32e00000.isi: CHNL_OUT_BUF2_ADDR_V[0x94]: 00
[ 36.523653] mxc-isi 32e00000.isi: CHNL_SCL_IMG_CFG[0x98]: 1e00280
[ 36.523656] mxc-isi 32e00000.isi: CHNL_FLOW_CTRL[0x9c]: 00
[ 36.867448] mxc-mipi-csi2.0: fmt: 0x3008, 640 x 480
[ 36.883597] mxc-mipi-csi2.0: --- mipi_csis_s_stream ---
[ 36.883603] mxc-mipi-csi2.0: CSIS_VERSION[0]: 0x03060301
[ 36.883605] mxc-mipi-csi2.0: CSIS_CMN_CTRL[4]: 0x00004b05
[ 36.883608] mxc-mipi-csi2.0: CSIS_CLK_CTRL[8]: 0x000f0010
[ 36.883610] mxc-mipi-csi2.0: CSIS_INTMSK[10]: 0x0fffff1f
[ 36.883612] mxc-mipi-csi2.0: CSIS_INTSRC[14]: 0x00000000
[ 36.883616] mxc-mipi-csi2.0: CSIS_DPHYSTATUS[20]: 0x00000002
[ 36.883621] mxc-mipi-csi2.0: CSIS_DPHYCTRL[24]: 0x0440001f
[ 36.883626] mxc-mipi-csi2.0: CSIS_DPHYBCTRL_L[30]: 0x000001f4
[ 36.883630] mxc-mipi-csi2.0: CSIS_DPHYBCTRL_H[34]: 0x00000000
[ 36.883636] mxc-mipi-csi2.0: CSIS_DPHYSCTRL_L[38]: 0x00000000
[ 36.883643] mxc-mipi-csi2.0: CSIS_DPHYSCTRL_H[3c]: 0x00000000
[ 36.883646] mxc-mipi-csi2.0: CSIS_ISPCONFIG_CH0[40]: 0x000000b0
[ 36.883651] mxc-mipi-csi2.0: CSIS_ISPCONFIG_CH1[50]: 0x000008fd
[ 36.883654] mxc-mipi-csi2.0: CSIS_ISPCONFIG_CH2[60]: 0x000008fe
[ 36.883657] mxc-mipi-csi2.0: CSIS_ISPCONFIG_CH3[70]: 0x000008ff
[ 36.883660] mxc-mipi-csi2.0: CSIS_ISPRESOL_CH0[44]: 0x01e00280
[ 36.883664] mxc-mipi-csi2.0: CSIS_ISPRESOL_CH1[54]: 0x80008000
[ 36.883667] mxc-mipi-csi2.0: CSIS_ISPRESOL_CH2[64]: 0x80008000
[ 36.883670] mxc-mipi-csi2.0: CSIS_ISPRESOL_CH3[74]: 0x80008000
[ 36.883673] mxc-mipi-csi2.0: CSIS_ISPSYNC_CH0[48]: 0x00000000
[ 36.883676] mxc-mipi-csi2.0: CSIS_ISPSYNC_CH1[58]: 0x00000000
[ 36.883679] mxc-mipi-csi2.0: CSIS_ISPSYNC_CH2[68]: 0x00000000
[ 36.883682] mxc-mipi-csi2.0: CSIS_ISPSYNC_CH3[78]: 0x00000000
[ 36.883686] mxc-mipi-csi2.0: --- mipi_csis_s_stream ---
[ 36.883691] mxc-mipi-csi2.0: GPR_GASKET_0_CTRL[60]: 0xffff8000
[ 36.883694] mxc-mipi-csi2.0: GPR_GASKET_0_HSIZE[64]: 0xffff8000
[ 36.883697] mxc-mipi-csi2.0: GPR_GASKET_0_VSIZE[68]: 0xffff8000
[ 36.883708] isi-capture 32e00000.isi:cap_device: mxc_isi.0.capture is no v4l2 subdev
[ 36.883734] isi-capture 32e00000.isi:cap_device: mxc_isi_cap_g_fmt_mplane
[ 38.891295] isi-capture 32e00000.isi:cap_device: cap_vb2_stop_streaming
media :
root@verdin-imx8mp-07154640:~# media-ctl -pd /dev/media0
Media controller API version 5.4.[ 1904.454865] mlx75027_get_fmt
193
Media device information
driver mxc-md
model FSL Capture Media Device
serial
bus info
hw revision 0x0
driver version 5.4.193
Device topology
- entity 1: mxc_isi.0 (16 pads, 2 links)
type V4L2 subdev subtype Unknown flags 0
pad0: Sink
<- "mxc-mipi-csi2.0":4 [ENABLED]
pad1: Sink
pad2: Sink
pad3: Sink
pad4: Sink
pad5: Sink
pad6: Sink
pad7: Sink
pad8: Sink
pad9: Sink
pad10: Sink
pad11: Sink
pad12: Source
-> "mxc_isi.0.capture":0 [ENABLED]
pad13: Source
pad14: Source
pad15: Sink
- entity 18: mxc_isi.0.capture (1 pad, 1 link)
type Node subtype V4L flags 0
device node name /dev/video0
pad0: Sink
<- "mxc_isi.0":12 [ENABLED]
- entity 22: mxc-mipi-csi2.0 (8 pads, 2 links)
device node name /dev/v4l-subdev0
pad0: Sink
<- "mlx75027 2-0057":0 [ENABLED,IMMUTABLE]
pad1: Sink
pad2: Sink
pad3: Sink
pad4: Source
-> "mxc_isi.0":0 [ENABLED]
pad5: Source
pad6: Source
pad7: Source
- entity 31: mlx75027 2-0057 (1 pad, 1 link)
type V4L2 subdev subtype Sensor flags 0
device node name /dev/v4l-subdev1
pad0: Source
[fmt:SBGGR12_1X12/640x480 field:none colorspace:raw]
-> "mxc-mipi-csi2.0":0 [ENABLED,IMMUTABLE]
since you use raw data, why don't you use ISP instead of ISI? and I don't think you need to add this
+ index = 3;
+else
+ index = 0;
refer to the source code,
/* Pixel link master will transfer format to RGB32 or YUV32 */ src_f->fmt = mxc_isi_get_src_fmt(&src_fmt);
so you just keep the index to 0 if you use raw12
HI:
Thanks for you reply.
In structure mxc_ isi_ src_ In formats, RAW12 is not supported, so the above pair is added.
Now I just need to get the raw12 data, so I used isi
My understanding is that isi stores sensor data directly into ram, while isp needs to cooperate with some parameters to convert images into yuv format. Is that right?
refer to the source code I sent to you, you don't need add this format, you can try to remove it, because you use index=3, but mxc_isi_src_formats structure only has two members, you can try it firstly
yes you are correct, ISI couldn't handle raw data, only capture and store in the memory
I have solved the problem that sensor data cannot be obtained.
1. My sensor mipi clk uses a continuous clock and does not enter the lps mode.
2. mxc_isi_pipeline_enable function, the starting sequence is sensor ->dphy ->csi2
The sensor starts before dphy, which causes dphy to fail to parse,i t seems that dphy does not support the continuous clock mode.
It can only detect the switch from low speed to high speed.
The solution is to set the sensor mipi clk to discontinuous mode.
I added 2 members to the mxc_isi_src_formats structure, so for BG12, the index value is 3
.name = "RGB32",
.fourcc = V4L2_PIX_FMT_RGB32,
.depth = { 32 },
.memplanes = 1,
.colplanes = 1,
.name = "YUV32 (X-Y-U-V)",
.fourcc = V4L2_PIX_FMT_YUV32,
.depth = { 32 },
.memplanes = 1,
.colplanes = 1,
.name = "SBGGR8",
.fourcc = V4L2_PIX_FMT_SBGGR8,
.depth = { 8 },
.memplanes = 1,
.colplanes = 1,
.name = "SBGGR12",
.depth = { 12 },
.memplanes = 1,
.colplanes = 1,
ok I don't see your whole source code, but in fact, imx8mp mipi csi can support continuous mode
Can you tell me how to modify the code to make imx8mp support continuous mode?
as I known, no special configuration for this
