Hello Folks,
I used the uuu tool to flashing the emmc of imx8mmevk board. The command "sudo uuu -b emmc_all <bootloader> <.rootfs.wic.bz2>" works fine but it take a long time to finish. I would like to know if it is possible to flashing only <bootloader> with uuu tools and after that flashing the <.rootfs.wic.bz2> over ethernet interface. Does anybody know how can I do that?
Thanks in advance.
Solved! Go to Solution.
Hi Oscavo
for flashing bootloader one can look at uuu documentation UUU.pdf
"Typical usage"
Burn uboot into emmc
uuu -b emmc bootloader
and sect.4.3.6 Copying the root file system (rootfs) i.MX Linux User’s Guide
Hi Oscavo
"Typical usage"
