imx6ul from qspi-flash boot firmware need to use qspi a?
776件の閲覧回数
shauew
hello,
       I saw the passage from the imx6ul manual (IMX6ULRM.pdf section 8.6.3)
“The QuadSPI Configuration Parameters Table is built in boot image at fixed offset 0x400 from QSPI NOR A1 base address (368 bytes).”
       Does that means qspi-flash boot need qspi a? Could i only use the qspi b ?
ラベル(3)
484件の閲覧回数
igorpadykov
port a is always available, port b is configurable.
485件の閲覧回数
igorpadykov
