imx6q spidev_test loopback test no RX
1,457件の閲覧回数
jongjyhhsieh
my goal is run a loopback test on the spi device.
So far, I configured pin map for SPI1 and SPI3 and enabled them on the board-specific file.
I can see spi1.0 and spi3.0 device node under /dev/.
I connected the SPI3's MISO to MOSI to run the loopback.
For the testing application used spidev_test.c which is under kernel document and just modified the device name to spidev3.0.
when I run the test app, below is what I get,
spi mode: 0
bits per word: 8
max speed: 500000 Hz (500 KHz)
00 00 00 00 00 00
00 00 00 00 00 00
00 00 00 00 00 00
00 00 00 00 00 00
00 00 00 00 00 00
00 00 00 00 00 00
00 00
I am expecting to get the same tx data for rx but I get 0 as above.
Let me know if anythig I have missed.
Thanks in advance,
3 返答(返信)
992件の閲覧回数
zengyi7761
    Have you solved this problem? I meet the same problem now......
992件の閲覧回数
pavleb
There was a bug in the pinctrl definitions in the mainline kernel.
Checkout this commit: 5040feb00c624e18c3a41c600883ab848c1f1f53
992件の閲覧回数
jimmychan
We have documentation for different version of Linux BSP.
i.MX 6 Series Software and Development Tool|NXP
for example :
In the documentation, there is i.MX_Linux_Reference_Manual.pdf
For the ECSPI, please read the Chapter 36. And 36.4 Unit Test for the test details.
