imx6q - Examples of using OpenGL and OpenCL in same app?
740件の閲覧回数
Robert_P
I'm on an imx6q, and I'm having trouble using OpenGL ES 2.0 and OpenCL 1.1 in the same app.
For example, let's say I have two separate apps: an OpenGL ES 2.0 app, and an OpenCL 1.1 app.
The OpenGL ES 2.0 app is the 01_SimpleTriangle example from the GPU SDK, running on the framebuffer using Makefile.fbdev.
The OpenCL 1.1 app is just a simple example app that performs a calculation on the GPU.
If I run the OpenGL ES 2.0 app by itself, it runs fine.  I see the triangle right side up on my display.
Likewise, if I run the OpenCL 1.1 app by itself, it runs fine.
Now I want to combine them.  In a render loop, I need a calculation to be done in OpenCL, and then I need to render using OpenGL.
But if I try to combine the two example apps into one app, the triangle gets rendered upside down.
I must be doing something wrong, but I haven't been able to figure out what.
Are there any simple examples of using OpenGL ES 2.0 and OpenCL 1.1 in the same app?
2 返答(返信)
586件の閲覧回数
b36401
Unfortunately there may be some conflicts between CL and GL texture structures.
Sorry for the inconvenience.
Victor
586件の閲覧回数
Robert_P
That is unfortunate.  Is there a conflict even if I'm using OpenCL buffer objects, and not using OpenCL image objects?
