in our custom based board we are using MT29PZZZ8D5BKFTF-18 W.95L(8gb emmc)4.51
when i am sending cmd0 then cmd1 to my emmc using jtag and i am not getting any response
for cmd1 i am probing cmd line which shows command trigger but no response after 56cycles also
i checked clock and power all seems good.what could be the reason of this kind of behaviour.
regards
swapnil
Hi swapnil
usually such behaviour is caused by hardware: broken lines or missing
power, suggest to check emmc signals with oscilloscope.
Hi igor,
i am using trace32 and cmm file in card identification mode but not getting
response from cmd1. Can you pls check my cmm file configuration
; @Title: i.MX6 eMMC FLASH Programming Script
; @Description:
; FLASH Type: eMMC FLASH(Numonyx, NAND16GAH0P) connected SDHC3
; S(D)RAM: 0x900000
; SDHC CS3 base: 0x2198000
; @Author: jjeong
; @Chip: IMX6SOLO
; @Keywords: MACRONIX MX25L25635F
; @Copyright: (C) 1989-2014 Lauterbach GmbH, licensed for use with TRACE32(R) only
; $Id: imx6solo-emmc.cmm 2881 2014-07-07 10:35:48Z kjmal $
&MMC_BASE=0x2198000
RESet
SYStem.CPU iMX6Solo ;SOLO
;CORE.ASSIGN 1 ;SOLO
SYStem.Option ResBreak OFF
SYStem.Option WaitReset 1.3s
Trace.METHOD Onchip
SYStem.Up
Data.Set C15:0x1 %Long (Data.Long(C15:0x1)&~(0x10005)) ; disable interrupt and mmu
Data.Set ASD:0x020d8000 %Long 0x01C00521 ;SRC Control Register
; Disable WDOG
Data.Set 0x020bc000 %Word 0x30
; Enable all clocks (they are disabled by ROM code)
Data.Set 0x020c4068 %Long 0xffffffff
Data.Set 0x020c406c %Long 0xffffffff
Data.Set 0x020c4070 %Long 0xffffffff
Data.Set 0x020c4074 %Long 0xffffffff
Data.Set 0x020c4078 %Long 0xffffffff
Data.Set 0x020c407c %Long 0xffffffff
Data.Set 0x020c4080 %Long 0xffffffff
Data.Set 0x020c4084 %Long 0xffffffff
; IO Mux for SDHC3
Data.Set 0x020E030C %LE %Long 0x0 ;IOMUXC_SW_MUX_CTL_PAD_SD3_CLK
Data.Set 0x020E0310 %LE %Long 0x0 ;IOMUXC_SW_MUX_CTL_PAD_SD3_CMD
Data.Set 0x020E0314 %LE %Long 0x0 ;IOMUXC_SW_MUX_CTL_PAD_SD3_DAT0
Data.Set 0x020E06F4 %LE %Long 0x0001B0B0 ;IOMUXC_SW_PAD_CTL_PAD_SD3_CLK
Data.Set 0x020E06F8 %LE %Long 0x0001B0B0 ;IOMUXC_SW_PAD_CTL_PAD_SD3_CMD
Data.Set 0x020E06FC %LE %Long 0x0001B0B0 ;IOMUXC_SW_PAD_CTL_PAD_SD3_DAT0
; Config SDHC
Data.Set &MMC_BASE+0x04 %LE %Long 0x00010200 ; blk size,cnt
Data.Set &MMC_BASE+0x28 %LE %Long 0x08800020 ; bus width, endian
Data.Set &MMC_BASE+0x2C %LE %Long 0x008E1088 ; 400KHz clk
//FLASH READ ID TEST
AREA.CLEAR
AREA.view
GOSUB READ_ID_TEST
DIALOG.YESNO "the flash id is correct on AREA window?"
ENTRY &result
IF !&result
PRINT "pls, check your register configuration to enable your flash controller"
ENDDO
//S(D)RAM TEST for algorithm file
;GOSUB SDRAM_INIT
Data.Test 0x900000++0x3FFF /Prime ;s(d)ram test
IF FOUND()
PRINT "s(d)ram is NOT initialized around 0x" ADDRESS.OFFSET(TRACK.ADDRESS())
ENDDO
programFlash:
FLASHFILE.RESet
;FLASHFILE.CONFIG <eMMC controller> <#partition> <0x0>
FLASHFILE.CONFIG &MMC_BASE 0x0
;FLASHFILE.TARGET <<code range>> <<data range>> <<algorithm file>>
FLASHFILE.TARGET 0x900000++0x1fff 0x904000++0x1fff ~~/demo/arm/flash/byte/emmc_imx6.bin /KEEP
FLASHFILE.GETID
Data.Set &MMC_BASE+0x2C %LE %Long 0x008E0188 ; 25Mhz clk, only allowed the data access commands on the higher clk
//Read FLASH Manufacture and Device ID
FLASHFILE.DUMP 0x0 ; Read
;FLASHFILE.ERASE 0x0--0xFFFFF ; Erase
;FLASHFILE.LOAD * 0x0 ; Write
ENDDO
READ_ID_TEST:
//CMD0
RePeaT 2.
Data.Set &MMC_BASE+0x30 %Long 0xFFFFFFFF ;clear status
Data.Set &MMC_BASE+0x8 %Long 0x0 ;arg
Data.Set &MMC_BASE+0xc %Long 0x0 ;cmd
WAIT 10.ms
//CMD1
RePeaT 10.
Data.Set &MMC_BASE+0x8 %Long 0x40FF8000 ;arg
Data.Set &MMC_BASE+0xc %Long 0x01020000 ;cmd1
&resp=Data.Long(A:(&MMC_BASE+0x10))
//print "CMD1 resp: 0x" &resp
IF (&resp&0x80000000)==0x80000000
GOTO jump_cmd2
PRINT "CMD1 fail"
END
jump_cmd2:
//CMD2
Data.Set &MMC_BASE+0xc %Long 0x02010000 ;cmd2
WAIT 10.ms
//CMD3
Data.Set &MMC_BASE+0x8 %Long 0x00010000 ; arg, MMC RCA is (0x0001<<16.)
Data.Set &MMC_BASE+0xc %Long 0x03020000 ;cmd3
WAIT 10.ms
//CMD10
Data.Set &MMC_BASE+0xc %Long 0x0A010000 ;cmd10
WAIT 10.ms
//Response2
PRINT "CID register"
PRINT "[127:104] 0x" Data.Long(A:(&MMC_BASE+0x1c))
PRINT "[103:72] 0x" Data.Long(A:(&MMC_BASE+0x18))
PRINT "[71:40] 0x" Data.Long(A:(&MMC_BASE+0x14))
PRINT "[39:8] 0x" Data.Long(A:(&MMC_BASE+0x10))
RETURN
SDRAM_INIT:
RETURN
