imx6Q,BCLK not work
imx6Q,BCLK not work
780 次查看
liupeiliu
1 The burst clock runs whenever ACLK is active (independent of chip select configuration)
I tried activating the BCLK continuously on my i.MX6Q board by setting ('1') the BCM bit (bit 0) on the EIM_WCR (0x021B_8090h) register.
I am not getting any clock on BLCK - constant '0'.
Did I forget anything?
here is my register configuration
MX6Q_PAD_EIM_BCLK__WEIM_WEIM_BCLK,  //pin_conf
writel(0x00020081, ram_reg);       //EIM_CS0GCR1
writel(0x00000001, ram_reg + 0x90);  // EIM_WCR
标签 (2)
标记 (3)
633 次查看
Yuri
  What is content of the following registers?
1.1.
  IOMUXC_SW_MUX_CTL_PAD_EIM_BCLK Pad Mux Register
at address: 0x020E_0158
1.2.
  IOMUXC_SW_PAD_CTL_PAD_EIM_BCLK Pad Control Register
at address: 0x020E_046C
2.
  According section 22.5.4 [Burst Clock Divisor (BCD)] of i.MX 6Dual/6Quad Applications Processor Reference Manual, Rev. 4, 09/2017:
“The BCM bit is used mainly for system debug mode. It has no functional use of the EIM in normal mode.” Note, the i.MX6 D/Q does not have special PLL for providing continuous BCLK, synchronized with internal (system bus) ACLK. This feature is supported in i.MX6 S/DL. So, for i.MX6 DQ we cannotguarantee, that BCLK in continuous mode is fully synchronized with ACLK.
Yuri
Note: If this post answers your question, please click the Correct
Answer button. Thank you!
633 次查看
liupeiliu
hello
these two Register value is reset value ,i  printed out the contents of the register,MUX_CTL_PAD(0158h) is 0 , PAD_CTL_PAD(046ch) is b0b1.
How do I set my board debug mode?
This feature is supported in i.MX6 S/DL. So, for i.MX6 DQ we cannotguarantee?
What does this mean?  the i.mx6Q does not supported??
