Hello guys,
Can I use imx6 L4.9.11 BSP with gstreamer-0.10? I checked this yocto L4.9.11, it use gstreamer-1.0, If I downgrade to gstreamer-0.10, will it work?
Thank you
Xiao
解決済! 解決策の投稿を見る。
Hi Xiao
supported gstreamer version is 1.10.4 as described in attached Release
Notes, as for gstreamer-0.10, it was not tested and its operation is not guaranteed.
Hi Xiao
Hi igor,
Thanks for your answer.
Our application use old gstreamer-0.10, so if we use this L4.9.11, the application need to update to gstreamer-1.10? Anything we can refer to the difference between gstreamer-0.10 and 1.10?
Thank you.
Xiao
Hi Xiao
yes with L4.9.11 the application needs to update to gstreamer-1.10, for
gstreamer usage one can look at Linux Guide included in documentation packages on link
Hi Igor,
Thank you so much.
Xiao
