iMXRT1024 DCP CRC-32 parameter settings
890件の閲覧回数
JasonGT93
I'm using the i.MX RT1024 evaluation board and trying to use the CRC32 to verify some data.
I used the dcp example without problem but when I tried to use the verify with an old data the result is not as expected cause of the settings.
The CRC32 included in the example use the parameters showns below:
width=32 poly=0x04c11db7 init=0xffffffff refin=false refout=false xorout=0x00000000
I know that these parameters are for CRC-32/MPEG-2 but my parameters are not exactly the same that these.
Is it possible to change these parameters?
2 返答(返信)
856件の閲覧回数
JasonGT93
Could anyone contribute?
Regards.
725件の閲覧回数
diego_charles
Hi @JasonGT93
I hope that you are doing great!
After checking , I am able to confirm that the RT1020 DCP do not have a provision to change CRC-32 parameters. So you can only compute for CRC32-MPEG-2.
I am sorry for the inconvenience.
Let me know if there is anything else to discuss.
All the best,
Diego
