iMX93 EVK LVDS
iMX93 EVK LVDS
2,206 次查看
coilnpark
I am using iMX93 11x11 evk.
When I checked LVDS Clock and signals in this evk board with the offered OS image full version from NXP, LVDS clock didn't output.
Is there any setting to output LVDS?
标记 (1)
2,178 次查看
Nobita
I use imx93-11x11-evk-boe-wxga-lvds-panel.dtb and the lvds panel works well, I think it's enough for you to check the clock with the same dtb file.
The imx93-11x11-evk-boe-wxga-lvds-panel dts does enable the lvds releated nodes and does disable the DSI2MIPI related nodes. I am not an expert, I am also consulting NXP's engineer about how to enable dual display with the same video output via hdmi and lvds.
2,190 次查看
Nobita
Have you change your dtb file since the default dtb does not enable lvds releated nodes.
2,182 次查看
coilnpark
Thank  you for your reply.
I tried to change the below file.
But it didn't work.
Do I have to change more?
arch/arm64/boot/dts/freescale/imx93-11x11-evk.dts
lvds_backlight: lvds_backlight {
              compatible = "pwm-backlight";
              pwms = <&tpm4 1 50000 0>;
              brightness-levels = <0 20 25 30 35 40 100>;
              default-brightness-level = <4>;
              status = "okay";
lvds_panel {
              compatible = "innolux,g121x1-l03","simple-panel";
              backlight = <&lvds_backlight>;
              port {
                          panel_lvds_in: endpoint {
                                      remote-endpoint = <&lvds_out>;
&ldb {
              status = "okay";
              lvds-channel@0 {
                          status = "okay";
                          port@1 {
                                      reg = <1>;
                                      lvds_out: endpoint {
                                                  remote-endpoint = <&panel_lvds_in>;
&ldb_phy {
              status = "okay";
