I am developing application on iMX8QM MEK EVK with Android Automotive OS 10.
I downloaded and compiled the Android Automotive OS 10 source codes from NXP's official site and I'm running on my board.
The type of my android image is "userdebug".
I want to run commands containing "su" authority in the application I have developed.
However, when I upload the apk to the board, I get a "Permission Denied" error in the command that works with "su".
How do I root this device directly?
Or what way can you suggest for this issue?
Efecan
Solved! Go to Solution.
Hi @efecancebel,
You could try using Android Debug Bridge (ADB) with the following commands:
$adb root
$adb disable-verity
$adb reboot
If you have any questions or concerns, don’t hesitate to let me know.
Best regards, Brian.
Hi @efecancebel,
$adb root
$adb disable-verity
$adb reboot
