iMX8MP / iMX8MM unique id
1,611 次查看
andreascian
Dear all,
I'm working with different iMX based platform, from iMX6* to iMX8*
We are used to look at SOC Unique ID to identify products on field because this is guarantee to be unique for each single component
I've notice a major changes between iMX8MP and the others (even iMX8MM for example): usually SOC Unique ID is a 32 bit number, but on iMX8MP is a 64 bit number
I'm wondering if we can use a 32 bit subset of these 64 bit and yet assume that this number is unique across all SOCs, so we can have a higher level of software compatibility across the whole iMX family
Any clue or additional information?
Kind Regards and Thanks in advance,
Andrea
1,288 次查看
andreascian
BTW a colleague of mine asked the same question to NXP dedicated support and have the confirm that:
The UID[127-64] located on bank 40, world 0 and word 1.
so we have an official answer to share.
Hope this help others in our same situation
6 回复数
1,577 次查看
Harvey021
Hi @andreascian
Sorry for replying to you with delay.
More details hope to help you, SoC UID is a read-only fuse value, which is programmed by the factory to identify a unique SoC, and this value is randomly generated. duplicate would happen if use only 32bits.
Harvey
1,575 次查看
andreascian
Hi Harvey
on iMX8MP I've also found some additional UNIQUE_ID bits into the fusemap, see fuse address 0xE00-0xE10 named as UNIQUE_ID[127:64]
Does it means that UNIQUE_ID is 128 bit wide on this platform?
1,569 次查看
Harvey021
That is correct.
Harvey
1,316 次查看
andreascian
sorry for replying to this old thread, but can you help me in figuring out which bank/register is associated with these upper 64 bits?
IIUC 0xE00 should correspond to bank 40 register 0 but can please confirm this?
1,289 次查看
andreascian
1,583 次查看
andreascian
I reply to myself because I also opened a support ticket. Support team already reply that I was wrong and SOC UniqueID is 64 bit in both iMX8MP and iMX8MM and that's guarantee unique only it's full 64 bit format
