iMX6SL UART debug issue.
911件の閲覧回数
yakovshaulov
I've a custom board based iMX6SL. One of the serial ports (UART1), for debugging, connects directly to a header, in a way to connect external UART to USB adapter. Our SW Engineer tried to debug through this port and has encountered a problem.
He sent bit stream from PC to our board (I can see the bit stream on the scope on RX line) but the board doesn't respond at all. i.e., we don't see any changes on the TX line from the iMX6SL, and it should happen.
As I understood, there is no any SW issue because, as SW engineer claims, he took the exactly code for debug on iMX6SL. So, probably is a HW problem.
On the other side, we do able to read and write to LPDDR through the USB port, and seems like the handshake between the LPDDR to iMX works properly.
Anyone have meet same problem?
Do I miss something and what could be the problem? Is it HW or SW isuue?
タグ(1)
4 返答(返信)
758件の閲覧回数
yakovshaulov
Can anyone explain to me what could be the problem?
758件の閲覧回数
igorpadykov
could you elaborate what do you mean saying
"MFG tool does not report any problem but the U-Boot does not send any
data out to the UART and does not respond to any command," ?
758件の閲覧回数
igorpadykov
Hi Yakov
what response is expected from board, is some program running on processor
and expecting data from uart ? One can attach jtag debugger and check
UARTx_URXD, UARTx_USR2 (RDR ready bit), also enable uart
clocks in CCM_CCGRn. Had valid uart baudrate programmed and
selection of register IOMUXC_UART1_UART_RX_DATA_SELECT_INPUT made.
758件の閲覧回数
yakovshaulov
We are using IMX6SL EVK BSP
We are trying to load U-Boot into RAM using MFG tool.
MFG tool does not report any problem but the U-Boot does not send any data out to the UART and does not respond to any command, even if we stop the MFG before jumping to the kernel, and instead U-Boot is called.
We didn't change any UART configuration but it should work on UART 1
So we expected to see any U-Boot promt.
