iMX6Q missing documentation for Analog LDOs
2,420 次查看
MichaelV
Senior Contributor III
I can't find the documentation for the LDO registers in the iMX6 reference manual.
There is a small section in the iMX6Q RM (50.3 Analog LDO Regulators) and and iMX6DL (51.3 Analog LDO Regulators) but there is no register description. The registers should be located at 20C_8110, but when searching for that in the RM nothing comes up.
Where can I find detailed info about these regulator registers?
标签 (5)
标记 (4)
2,107 次查看
Hi, Michel
all available for customers information about LDO registers is given in
Chapter 51 "Power Management Unit (PMU)" i.MX6SDL Reference Manual (rev.1  5/2013)
http://cache.freescale.com/files/32bit/doc/ref_manual/IMX6SDLRM.pdf
2,107 次查看
MichaelV
There is no register description there. I'm looking for the analog LDO regulator register descriptions, located at 0x020C8110.
I'm looking for the description of the registers with names: REG_1P1, REG_1P1_SET/CLR/TOG, REG_3P0, REG_3P0_SET/CLR/TOG, REG_2P5, REG_2P5_SET/CLR/TOG, REG_CORE, REG_CORE_SET/CLR/TOG
I can't find those descriptions in the RMs for iMX6 (DQ or DL).
2,107 次查看
Hi, Michel
descriptions will be added in next rev.2.0 Reference Manual.
Alternatively you can enter support ticket to obtain it earlier.
chip
