I guess my setup_timer fails, any help is appreciated.
Solved! Go to Solution.
Thanks igor,
MATRIX_KEY
macro is not defined in the daisy branch.
My problem was that IOMUX implemented in .dtsi file is not reflected in registers.
I have exclusively write those registers using a bash script.
Piyush Ashtikar.
Thanks igor,
MATRIX_KEY
Piyush Ashtikar.
How to write these registers using bash script?
Hi piyush
keypad is used on i.MX6SL EVK please check imx6sl-evk.dts
http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/tree/arch/arm/boot/dts/imx6sl-evk.dts?id...
