iMX6_MAX board is rebooting after flashing QNX sdp7.0 BSP
1,505件の閲覧回数
chethankumar
I downloaded QNX BSP from below link
QNX SDP 7.0 for i.MX platforms - Boundary Devices
I copied bootscript and qnx-ifs to the sd card and put that inside iMX6_MAX board. My board is rebooting again and again. Please find the log below i am seeing during u-boot. Please help me to resolve this issue.
U-Boot 2015.07-15072-g45cfc85 (Jan 28 2016 - 17:41:33 -0700), Build: jenkins-uboot_v2015.07-30
CPU: Freescale i.MX6Q rev1.2 996 MHz (running at 792 MHz)
Reset cause: WDOG
Board: Nitrogen6_max
I2C: ready
DRAM: 3.8 GiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
SF: Detected SST25VF016B with page size 256 Bytes, erase size 4 KiB, total 2 MiB
auto-detected panel hannstar7
Display: hdmi:1920x1080M@60 (1920x1080)
In: serial
Out: serial
Err: serial
Net: using phy at 6
FEC [PRIME], usb_ether
Hit any key to stop autoboot: 0
AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: ncq stag pm led clo only pmp pio slum part
No port device detected!
** Bad device size - sata 0 **
switch to partitions #0, OK
mmc0 is current device
reading /6x_bootscript
195 bytes read in 11 ms (16.6 KiB/s)
## Executing script at 10008000
reading qnx-ifs
11301012 bytes read in 512 ms (21 MiB/s)
Starting QNX...
## Starting application at 0x10800000 ...
Reset cause: WDOG
I2C: ready
DRAM: 3.8 GiB
In: serial
Out: serial
Err: serial
Net: using phy at 6
reading qnx-ifs
Starting QNX...
CK@
タグ(2)
1,221件の閲覧回数
gary_bisson
Senior Contributor III
Yes, this question was answered via our support channel.
Please try not to cross post your questions.
Gary
3 返答(返信)
1,221件の閲覧回数
gusarambula
Hello gary_bisson, would you know what could be the cause of this behavior?
1,222件の閲覧回数
gary_bisson
Gary
1,221件の閲覧回数
chethankumar
Thank you for the reply.
CK
