iMX28 defconfig Power Management options
781 次查看
nxp_jbmbtbklg
Hi all,
I want to learn the meaning of the power management parameters listed below in the imx28evk_defconfig.dev file:
# Power management options
CONFIG_PM=y
# CONFIG_PM_DEBUG is not set
CONFIG_PM_SLEEP=y
CONFIG_SUSPEND_NVS=y
CONFIG_SUSPEND=y
CONFIG_SUSPEND_FREEZER=y
# CONFIG_APM_EMULATION is not set
CONFIG_PM_RUNTIME=y
CONFIG_PM_OPS=y
CONFIG_ARCH_SUSPEND_POSSIBLE=y
CONFIG_NET=y
Any help?
Thank You!
标签 (2)
699 次查看
igorpadykov
Hi Jesus
seems some configs are generic, described in common linux
documentation, also one can look at attached i.MX28 Linux Manual Chapter 8
i.MX28 Static Power Management Driver
700 次查看
igorpadykov
Hi Jesus
