i.mx6 IPU rotate 180 degree
2,042件の閲覧回数
zc_tee
Hi all,
Is the i.mx6 IPU able to do 180 degree rotation in kernel?
In drivers/video/mxc/mxc_ipuv3_fb.c, I saw that there are two lines as below:
     if(var->rotate > IPU_ROTATE_VERT_FLIP)
          var->rotate = IPU_ROTATE_NONE;
Does it means the IPU only can do vertical flip? why is these two lines in the coding?
I am using kernel version 3.0.101.
Tee
ラベル(3)
タグ(3)
4 返答(返信)
839件の閲覧回数
igorpadykov
Hi Tee
rotation and flip is supported by IPU, for examples one can look at
https://community.nxp.com/docs/DOC-94961
839件の閲覧回数
zc_tee
Hi Igor,
I see the example is implemented in application level.
I need it to be done in kernel level, is it possible?
Due to mechanical constraint, our display is to be mounted 180 degree rotated. Therefore, all of our display (console, UI, OS, application) needs to be rotated.
I think it would be easier to default it to 180 degree rotate in kernel.
Tee
839件の閲覧回数
igorpadykov
Hi Tee
one can try to reuse attached sdk example in ipu\src\ipu_ic.c
description in attached document sect.18.4.2 Main processing
839件の閲覧回数
zc_tee
Hi Igor,
I cannot understand that why in the kernel source drivers/video/mxc/mxc_ipuv3_fb.c there is a straight implementation on rotating the display and yet we cannot use it?
By saying try to reuse attached sdk example in ipu/src/ipu_ic.c, does it means that i need to incorporate the stated source into my kernel source drivers/mxc/ipu3/ipu_ic.c? Is there any patch that can be applied?
Thank you.
Tee
