i.MX8M display with EDP panel
6,553件の閲覧回数
lizboxy
由于采用i.MX8M要适配多尺寸的屏幕,需要用到EDP屏。
但现在碰到显示的问题:使用dual lane edp 屏幕开机一直显示 No EDID function
我的设备树如下, 附件是SCH,请帮忙确认这是硬件还是软件哪里的问题?能否给点建议?谢谢!
&hdmi {
             compatible = "fsl,imx8mq-dp";
            lane_mapping = <0xc6>;
            fsl,edp; edp_link_rate = <0x6>;
            edp_num_lanes = <0x2>;
            status = "okay";
32 返答(返信)
2,719件の閲覧回数
Zhiming_Liu
你试一下在UBOOT里设置dp固件
setevn panel dp_fw
saveenv
2,707件の閲覧回数
lizboxy
Uboot 输入setenv panel dp_fw
saveenv
仍然不显示,打印消息一样
2,535件の閲覧回数
Zhiming_Liu
这可能是固件问题,我在问专家了
2,460件の閲覧回数
lizboxy
有没有新的进展?
2,416件の閲覧回数
Zhiming_Liu
AE那边需要添加drmdebug后的log,你附一下
2,380件の閲覧回数
lizboxy
Uboot 中添加dp 固件后,可以正常读到EDID,但是还是会报错,请帮忙看看是哪里的问题。
全部log如附件所示,谢谢!
[    2.441966] imx-dcss 32e00000.display-controller: bound 32c00000.hdmi (ops cdns_mhdp_imx_ops)
[    2.450801] [drm] Initialized imx-dcss 1.0.0 20190917 for 32e00000.display-controller on minor 0
[    2.463816] cdns-mhdp-imx 32c00000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
[    2.478924] cdns-mhdp-imx 32c00000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
[    2.479094] [drm] Mode: 1920x1080p147800
[    2.673576] imx-dcss 32e00000.display-controller: Pixel clock set to 147789 kHz instead of 147800 kHz.
[    2.718677] cdns-mhdp-imx 32c00000.hdmi: [drm:cdns_mhdp_train_link] *ERROR* clock recovery failed
[    3.194667] cdns-mhdp-imx 32c00000.hdmi: [drm:cdns_mhdp_train_link] *ERROR* training failed: -110
[    3.194675] cdns-mhdp-imx 32c00000.hdmi: [drm:cdns_mhdp_train_link] *ERROR* Failed to start training -110
[    3.194684] cdns-mhdp-imx 32c00000.hdmi: [drm:cdn_dp_bridge_enable] *ERROR* Failed link train -110
2,378件の閲覧回数
lizboxy
/ SPDX-License-Identifier: GPL-2.0
 * Copyright 2019 NXP.
#include "imx8mq-evk.dts"
&irqsteer {
         status = "okay";
&dcss {
         status = "okay";
         disp-dev = "hdmi_disp";
         port@0 {
                 dcss_out: endpoint {
                          remote-endpoint = <&hdmi_in>;
&hdmi {
         compatible = "cdn,imx8mq-dp";
         lane-mapping = <0xc6>;
         status = "okay";
         port@1 {
                 hdmi_in: endpoint {
                          remote-endpoint = <&dcss_out>;
2,551件の閲覧回数
Zhiming_Liu
你的附件还没上传,另外提供一下完整的log
Zhiming
2,460件の閲覧回数
lizboxy
目前使用的是5.4.70的内核,设备树如下,打印信息以及原理图如附件,还请建议,谢谢!
 &irqsteer {         status = "okay";
 &dcss {
            status = "okay";
            port@0 {
 &hdmi {
              status = "okay";
              port@1 {
                            hdmi_in: endpoint {
2,456件の閲覧回数
Zhiming_Liu
OK,我在帮你看了
タグ(1)
2,467件の閲覧回数
lizboxy
请参考附件SCH。
749件の閲覧回数
Lin113
請問 您的問題有解決了嘛?
目前我們也遇到edp無法顯示的問題
