At i.MX8MQ, we used SDP to download data (~2K bytes) to a memory address.
e.g.
uuu sdp: write -f data.bin -addr 0x184000
However, i.MX8M Plus changed to SDPS. How to use SDPS to download data to a memory address 0x184000.
The main purpose is to load the DDRC setting without rebuilding the uboot.bin file. Just download the data to memory and use it at bootup.
If you want to debug uboot.bin, you need get relocate address from uboot using command "bdinfo",then use uuu download it to ram relocate address.
Zhiming
