i.MX8M Mini MIPI-DPHY
pierluigi_p
Contributor V
is there any part of the Linux BSPs exposing the access to MIPI_DPHY_M_PLLCTL as detailed in section 13.6.10.2 of the i.MX 8M Mini Applications Processor Reference Manual?
Best Regards
Pier
Tags (2)
Hi Pier
for access to registers one can try memtool
https://source.codeaurora.org/external/imx/imx-test/tree/test/memtool?h=imx_5.4.70_2.3.0
pierluigi_p
Contributor V
Hi Igor,
thanks for the suggestion, but I was looking for something kernel side.
Is there any kernel driver managing any of the 5 registers of MIPI_DPHY from section 13.6.10 of the Reference Manual?
Best Regards
Pier
Hi Pier
one can check sect.6.4.2 MIPI DSI Interface   i.MX Linux Reference Manual​
https://source.codeaurora.org/external/imx/linux-imx/tree/?h=imx_5.4.70_2.3.0
pierluigi_p
Contributor V
Hi Igor,
I've already reviewed the code of the kernel driver, but I'm not able to find any reference to any of these 5 MIPI_DPHY registers.
Can you provide any additional reference?
Best Regards
Pier
