i.MX8 QXP DDR3L-1866 validation card
477 次查看
brynnehunt
I am developing a board with the IMX8X QXP processor. I am using DDR3L memory with sideband ECC. Can I have access and files for the i.MX8 QXP DDR3L-1866 validation card? Can you also confirm if I will need to use 2 separate DDR3L ICs to accomplish this design with ECC (i.e. do i need a 32-bit and 8-bit DDR3L both on the board?)
Thank you!
Brynne
342 次查看
brynnehunt
Thank you for the response-- may I please be sent the schematics? I FWD'd the mutual NDA already, I just want to make sure you all got it!
350 次查看
JosephAtNXP
Thank you for your interest in NXP Semiconductor products,
Yes, you need another device, you could use one or two memories for the 32-bit line and you will need an extra device for sideband ECC.
For documentation you could start at:
ECC on i.MX 8 Series
For schematics side, they will be sent over email.
