i.MX8 QXP DDR3L-1866 validation board
1,599 次查看
xinjian1
I'm developing a new board with i.MX8 QXP MCU, will use DDR3L with ECC. On the document i.MX8 QM / i.MX8 QXP Hardware Developer’s Guide there are some recommendations for 16-bit DDR3L devices in a fly-by topology, where can I find the design files of i.MX8 QXP DDR3L-1866 validation board?
Thanks.
Xinjian
1,548 次查看
xinjian1
15 回复数
1,320 次查看
reinerseifried
could you send me the brd and design files of the QXP DDR3L-1866 validation boards?
my ticket nb: 00502938
Thank you and best regards
Reiner
1,316 次查看
joanxie
mailed to you, please check it
1,594 次查看
joanxie
pls refer to the hardware design guide for detailed inforamtion
"https://www.nxp.com/products/processors-and-microcontrollers/arm-processors/i-mx-applications-proces...
1,592 次查看
xinjian1
Thanks for your quick reply, but the link seems not working, it shows "Page Not Found"
Xinjian
1,580 次查看
joanxie
1,577 次查看
xinjian1
Thanks, this is the main page of the i.MX 8X MCU but there's EVK board and some others,  I'm looking for DDR3L-1866 validation board design, the board is mentioned on page 42 of i.MX8 QM / i.MX8 QXP Hardware Developer’s Guide, and some routing layers on next pages, but there's no schematic in the file:
Could you please send those design files to me?
Xinjian
1,564 次查看
joanxie
1,561 次查看
xinjian1
I already have the design files of MEK board, which has i.MX8 QXP + LPDDR4 on board. However the design files I'm looking for are design files of i.MX8 QXP DDR3L-1866 validation board, which has i.MX8 QXP + 3 pieces DDR3L on fly-by topology with ECC function, might be the "sch-29848_a1", mentioned on "MX8X_Hardware_developers_Guide_V1_20100430.PDF":
1,556 次查看
joanxie
I have mailed to you,  pls check it
1,375 次查看
dmaier
Hi, could you also send me the brd and design files of the QXP DDR3L-1866 validation boards?
best regards
Dominik M.
1,364 次查看
joanxie
pls submit a ticket for this request, you can add the case number here, if I get this, I will send  mail to  you
"https://www.nxp.com/support/support:SUPPORTHOME?tid=sbmenu"
1,359 次查看
dmaier
I created a ticket (case number: 00502182).
Dominik M.
1,360 次查看
dmaier
Dominik M.
1,354 次查看
joanxie
my colleague has already assigned this, she will continue helping you, any questions, you can tell me too
1,549 次查看
xinjian1
Thanks a lot.
