i.MX6Q (android 7.1.2) : very weird behavior - help me. part I.
1,109 次查看
jasonoh
Good Day! Everyone!
We have a custom i.MX6Q board. (DDR + SD I/F)
We have ported u-boot, kernel, android to our board by following Android_User's_Guide.pdf.(android_N7.1.2_2.0.0)
Then we have programmed images to 16GB SD(micro)card using ~/myandroid/device/fsl/fsl-sdcard-partition.sh.
The very first booting is OK. Everything is fine. Please check 'First-booting.mp4' in part I.
But after second(third, fourth..) booting, there are only status bar and back button except all gone.
Please check 'After-Second-booting.mp4' in part II. If you have experienced this, I would like to hear some advice.
Best Regards.
Jason Oh.
标签 (2)
986 次查看
jasonoh
Good Day, Diego!
This is Jason Oh.
I have ported Android_N7.1.1_1.0.0.
It works as I expected. There is no problem. (but, many "avc:denied ...." messages <= I am a novice in SELinux area.)
In my opinion, it seems to be a GPT partition problem.
The time for this project is short, and I have decided to porting Android_N7.1.1_1.0.0.
The next step is porting an audio codec. (WM8960).
Dear Diego, Are you a NXP's staff?
If so, please help us(me) a lot in the future.
Thank you very much.
Best Regards.
Jason Oh
4 回复数
986 次查看
diegoadrian
Can you please share your log. Probably is a hardware problem.
Diego.
987 次查看
jasonoh
Good Day, Diego!
This is Jason Oh.
Best Regards.
Jason Oh
986 次查看
diegoadrian
Hello Jason,
I am glad that your problem was solved. However, if you are willing to have some help in the future, I recommend you to submit a case.
Diego.
986 次查看
jasonoh
Hi, Diego.
Thanks for your reply.
Yes. I thought it was a hardware problem.
But, when I have ported Android_M6.0.1_2.1.0, there is a no problem. Everything is OK.
So, I am currently trying to port Android_N7.1.1_1.0.0.
I will let you know when it finished.
I think there is a problem between GPT partition and SD card in our system. (<= just guess).
Best Regards.
Jason Oh
