i.MX6DQ PWM waveform is discontinuity when changes duty.
1,405 次查看
satoshishimoda
Senior Contributor I
Hi community,
I have a question about i.MX6DQ PWM.
Our partner want to change the PWM duty with same frequency, but the waveform discontinuity is occurred when changes PWM duty as attached file.
To prevent this issue, what should we do?
If you need  more information, please tell me what you need.
Satoshi Shimoda
标签 (2)
标记 (1)
985 次查看
igorpadykov
Hi Satoshi,
PWM has FIFO to avoid this issue.
Probably customer utilized all FIFO samples.
The PWM will run at the last set duty-cycle setting if all the values of
the FIFO has been utilized, until the FIFO is reloaded.
Please read carefully Reference Manual PWM chapter.
Example usage of PWM one can look at SDK below
i.MX 6Series Platform SDK : Bare-metal SDK
chip
6 回复数
986 次查看
igorpadykov
Hi Satoshi,
chip
985 次查看
satoshishimoda
Hi chipexpert,
According to your reply, something was wrong when changing the duty of PWM?
Should I confirm the detail of procedure of changing the PWM duty?
Satoshi Shimoda
985 次查看
igorpadykov
Hi Satoshi,
my reply was that FIFO should be always
filled (not empty) and check issue with SDK.
chip
985 次查看
satoshishimoda
Hi chip,
Thank you for your reply.
But this issue was occurred on MCIMX6DL-SDP with jb4.2.2._1.1.0 also as attached image, so I think this is BSP issue.
Please see the how to reproduce as following.
1. Boot jb4.2.2._1.1.0 on MCIMX6DL-SDP.
2. Probe DISP0_CONTRAST signal by oscilloscope.
2. Settings -> Display -> Brighness, change brightness.
Satoshi Shimoda
985 次查看
igorpadykov
Hi Satoshi
for Android issues please create new thread.
This thread was answered as hardware issue, not
associated with any operating system.
Software issues and hardware are considered separately.
chip
985 次查看
satoshishimoda
Hi chipexpert,
OK, I will create a new thread about android pwm.
I appreciate you support.
Satoshi Shimoda
