Hi community,
I have a question about i.MX6DQ PLL.
Please see chapter 18.7 in IMX6DQRM Rev.2, it says as below.
"The registers which have the same description are grouped within {}."
Then, would you let me know why the registers are grouped?
And would you let me know the role of each registers in the group?
(e.g. CCM_ANALOG_PLL_xxx_SET is for PLL enable, CCM_ANALOG_PLL_xxx_cler is for PLL disable,e etc...)
Satoshi Shimoda
解決済! 解決策の投稿を見る。
Hi Satoshi
registers descriptions are grouped since they have the same
meaning and for reducing document size.
Explanation of _SET, _CLR,_TOG can be found in
sect.39.2 Naming Convention IMX23RM
and they allow for bits manipulation.
Hi Satoshi
