i.MX6 dual-stream H.264 encoding
945 次查看
oliviersingla
Is there a C example how to do a dual-stream H.264 encoding ?
I tried to create a second instance of an H.264 encoder, but I got -17 error (RETCODE_FAILURE_TIMEOUT) from function vpu_EncStartOneFrame().
I was doing 720P for the primary encoding (works fine), and trying QVGA for the second encoding.
Thanks!
534 次查看
ruiguifang
hi,have you ever solved this question,if so,can you share your solution to me ,THX
