i.MX6 SOLO HDMI Support
855件の閲覧回数
mohammedazlum
Hi Team,
According to the datasheet MCIMX6S1AVM08AD part doesn't support VPU and GPU. However when we go through the datasheet it can support HDMI, LVDS, RGB, LVDS display from IPU.
May I know how the same CPU (MCIMX6S1AVM08AD ) can support these display when there is no VPU ? There should be some image format to display the content on display. So when there is no VPU how the encoding and decoding is occurs on the display ?
Azlum
840件の閲覧回数
weidong_sun
>>What will be the default display format at display modules when there is no VPU ?
--VPU has no relations to display, it means VPU doesn't affect display funtion.
--The output of the display interface: LVDS(0/1)/RGB24/HDMI/MIPI DSI
You can control which interface is used to output display data in the u-boot environment variable.
In linux BSP, the default is LVDS1.
B.R,
weidong
3 返答(返信)
841件の閲覧回数
weidong_sun
B.R,
weidong
848件の閲覧回数
weidong_sun
Hi mohammedazlum ,
See below,please!
The display is only related to IPU. The VPU is a module used to support H.264/MPEG4 encoding and decoding, and has nothing to do with display.
You can only decode and encode video data through software. However, the performance will be far from ideal.
Therefore, if you need H.264/MPEG4 encoding and decoding functions, 2D and 3D acceleration functions, it is best to choose a processor part number with VPU and GPU.
Hope  this information is helpful to you.
Have a nice day!
B.R,
Weidong
845件の閲覧回数
mohammedazlum
Dear Weidong,
Thanks for the reply.
Azlum
