i.MX6: Problem of configuration of the frame rate for the encoding VPU
513件の閲覧回数
gaylordlebrun
I would want to record videos with of multiple framerate (24,25,30) by means of the VPU ( vpu_lib ).
When I inform fields " frameRateInfo " of my variable EncOpenParam and after I call to the function" vpu_EncOpen () ", the video possesses a framerate of 25 fps all the time.
Will you have subjestions to solve my problem?
Thank you in advance for any answers.
Cordially
Gaylord
ラベル(4)
2 返答(返信)
418件の閲覧回数
Bio_TICFSL
Hi Gaylord,
The Video Processing Unit (VPU) of i.MX6 series processors can encode/decode a video streams at up to 1920x1080@30fps resolution/frame rate.
I Don't understand your question, you want to encode multiple frame rate? you can't.
418件の閲覧回数
gaylordlebrun
Thanks Bio_TICFSL,
Yes, I want, for example, encode a video streams in 1280x720@24fps but i can't change a encode framerate at the VPU. If i encode this video stream, i watch than video stream is encode in  1280x720@25fps.
Gaylord
