i.MX6 MAX die temperature
1,715件の閲覧回数
diegoferraiuolo
in my application I'm using  an i.MX6-quad.
I measure the die temperature by:
cat/sys/class/thermal/thermal_zone0/temp.
What is the upper limit I should consider for this value  so that the product
works in a safe condition?
Thanks in advance.
Diego
987件の閲覧回数
art
The maximum die temperature is sepcified as the 'Junction Temperature' parameter in the corresponding part's Data Sheet document.
Artur
2 返答(返信)
987件の閲覧回数
SergioSolis
The datasheet is located here:
http://www.nxp.com/files/32bit/doc/data_sheet/IMX6DQCEC.pdf
you can check table 4.1.3
988件の閲覧回数
art
Artur
