i.MX6 IOMUX output
i.MX6 IOMUX output
ko-hey
Senior Contributor II
I am designing a system with i.MX6 processor.
And I have a question about IOMUX.
In the case that shows in attachment, What is the output signal of IOMUX ?
Is it "High" or "Low" or "Uncertain" ?
Please clarify,
Sincerely
igorpadykov
Hi ko-hey
output signal of IOMUX will be "default in", high or low
(there is no strict rule) may depend on particular IOMUX register.
igorpadykov
Hi ko-hey
ko-hey
Hi Igor
Thank you for your reply.
I understood that output signal of IOMUX will be "high" or "low".
Which register do you meam?
ko-hey
igorpadykov
Hi ko-hey
there is no register, it is done internally.
~igor
ko-hey
Hi Igor
OK. Thanks.
ko-hey
