i.MX 8 EVK PMIC
i.MX 8 EVK PMIC
420件の閲覧回数
suhas_mv
With reference to i.MX8 EVK(SPF-31399_C2 file), the PMIC used in EVK is ROHM:BD71847MWV. In this regard can you please clarify the following:
Are the power up and power down sequences of PMIC preprogrammed ? i.e Chip is factory programmed (OTP). We assume there is no additional PMIC programming is required and hence can be directly interfaced to i.MX8. Please confirm?
Suhas
371件の閲覧回数
joanxie
yes, for more detailed information about power sequence, pls refer to the data sheet of imx8mm:
https://www.nxp.com/docs/en/data-sheet/IMX8MMCEC.pdf
