i.MX 6Quad SABRE-SD platforms -- split frame
1,012 次查看
alandeng123
I am using
i.MX 6Quad SABRE-SD CSI to get grey scale image from a camera sensor.
But the first frame is split as seem in the attached file.
photo comes from different frames from sensor.
This only happens on the first frame to user space.
Any suggestion on this.
921 次查看
weidong_sun
Hi Alan,
    I asked colleague working in expert team about your question , expert answer is the following:
The camera sensor should be enabled first, then IPU CSI enabled to capture.
So please check your operation about IPU and sensor !
Weidong
922 次查看
weidong_sun
Hi Alan,
Weidong
