glTexDirectVIVMap and YUV420p
1,263 次查看
ortogonal
Hi!
I'm using the VPU to decode HD movie and trying to display the movie by using glTexDirectVIVMap. I have a simple question, and it may have a really simple answer due to my little knowledge about video encoding. But all the sample HD movies I found uses YUV420P colospace and that is not a format that is supportet by glTexDirectVIVMap. How can I solve this? Is it possible to do somethin in the IPU before and make the color space conversion there, or is it possible to write a fragment shader that makes the color conversion.
The result I end up with is a really smooth playing movie but with wrong colors.
Thanks!
Erik
标签 (3)
602 次查看
igorpadykov
Hi Erik
colospace conversion can be done by both IPU and GPU,
examples can be found below
https://community.freescale.com/docs/DOC-94961
Freescale/gstreamer-imx · GitHub
AN4629 Fast Image Processing with i.MX 6 Series
gpu - texture for YUV420 to RGB conversion in OpenGL ES - Stack Overflow
