full memory test
full memory test
956件の閲覧回数
puneeth989
      I am trying to do full dram memory test from the user space in imx6q sabre sd. But if I run my code, system will hang. I know the problem is with already using memory.
Please give the solution to test my code. I don't want to use memtester, I want to run my own code.
Here i attached my code.
タグ(1)
916件の閲覧回数
igorpadykov
Hi PUNEETH
for testing memory recommended linux memtester
https://linux.die.net/man/8/memtester
If you are writing own test one can try to find where it hangs debugging and using
AN4553 Using Open Source Debugging Tools for Linux on i.MX Processors
https://www.nxp.com/docs/en/application-note/AN4553.pdf
