fail to use opencl on i.mx6Dual
1,120 次查看
zhengfudi
Hi, i am trying to use opencl on i.mx6Dual with BSP_Linux_3.14.28, but it returned -1001 when invoke clGetPlatformIDs(1, &platform_id, &platforms). I have checked CONFIG_MXC_GPU_VIV in kernel config, and "/dev/galcore" is also exist after bootup.
Does BSP_Linux_3.14.28 or i.mx6Dual not support opencl EP ? How to get a BSP supporting opencl?
Thanks a lot.
标签 (2)
标记 (1)
844 次查看
igorpadykov
4 回复数
844 次查看
igorpadykov
Hi zheng
bsp supports it, please refer to attached Linux Manual
Chapter 13 Graphics Processing Unit (GPU). For usage one can refer to
OpenCL Hello World
Where can we find the OpenCL BSP for i.MX6 Android?
844 次查看
zhengfudi
Hi igorpadykov
Thank you for your reply.
Actually, I configured the kernel refer to "Chapter 13 in Linux Manual", and copied the application code from "OpenCL Hello world". The programs compiled, linked and run success, but application invokes clGetPlatformIDs interface fail, return value is -1001. What is the cause of the problem may be?
845 次查看
igorpadykov
844 次查看
zhengfudi
Thanks.I deleted the old codes, and retried with codes witch download from above link. It worked well.
