display flickers during startup
1,039件の閲覧回数
celiley
I am using iMX6QuadPlus processor with TFT display. The designed board for display meets all electrical and timing requirements on the datasheet. The display flickers at start-up and reset time for 1-2 seconds then works fine. Below is the oscilloscope image including data enable, clock and data signals. The area between cursors belongs time of flickering state. Is there any way to deactive data enable signal?  I guess it's about to modules before Display Interface block of IPU but I couldn’t find what can cause this problem.
Glad if you help me
Celile
ラベル(2)
タグ(3)
2 返答(返信)
971件の閲覧回数
igorpadykov
Hi Celile
one can try to set necessary level in plugin :
plugin.S\mx6sabresd\freescale\board - uboot-imx - i.MX U-Boot
Also may be recommended to check display power up sequence
defined in its datasheet. One can consider below patches;
https://community.nxp.com/docs/DOC-98109
971件の閲覧回数
celiley
Sorry for the late reply. The problem has solved when display pin configurations moved from BSP to DI module in system load. Thank you for your help
