/dev/fb0 relation to IPU
916件の閲覧回数
robertspriggs
I'm using a custom i.MX6dl board with Linux. I have found using GStreamer sometimes that if I pause playback, then capture /dev/fb0, the image I get is a frame before what I see paused on the screen coming out of the IPU. Can anyone give me an idea what might be happening?
-Rob.
ラベル(5)
3 返答(返信)
788件の閲覧回数
igorpadykov
Hi Rob
what bsp/gstreamer used in the case, please try with nxp bsps described on
http://www.nxp.com/products/software-and-tools/software-development-tools/i.mx-software-and-tools/i....
http://git.freescale.com/git/cgit.cgi/imx/linux-imx.git/tree/?id=rel_imx_4.1.15_2.0.0_ga&h=imx_4.1.1...
and gstreamer usage in sect. 7 Multimedia attached Linux Guide
788件の閲覧回数
robertspriggs
A new BSP is not an option. I built the i.MX GStreamer plugins from source code I found here: GitHub - Freescale/gstreamer-imx: GStreamer 1.0 plugins for i.MX platforms
After further investigation, I've found that pausing video often causes a jump of several frames ahead (sometimes 5 or 6) for what is on screen, but /dev/fb0 seems to contain the correct frame where the video SHOULD be paused. I think unless someone has an answer, my best recourse is to analyze the i.MX plugin source code. For our application we need a pause to be a true playback freeze.
788件の閲覧回数
igorpadykov
gstreamer-imx plugins are not nxp software, it is supported through community,
please check maintainer of gstreamer-imx plugins mentioned on
https://community.nxp.com/thread/445732
difference between community gstreamer-imx plugins and nxp gstreamer plugins
described on
trac.gateworks.com/wiki/Yocto/gstreamer
