cl-som-imx8 yocto - NXP BSP source repo sync failure
1,622 次查看
ecsatya
I need to use the yocto build for cl-som-mx8 board and trying to sync the repo;
i'm following the instructions given @ https://github.com/compulab-yokneam/meta-compulab-imx8/wiki/01.-Build-CompuLab-Images
The repo sync is failing
> repo sync
Fetching project meta-fsl-bsp-release
Fetching project meta-openembedded
Fetching project meta-qt5
Fetching projects:  22% (2/9)  Fetching project meta-browser
Fetching projects:  33% (3/9)  Fetching project meta-freescale-distro
Fetching projects:  44% (4/9)  Fetching project poky
Fetching projects:  55% (5/9)  Fetching project meta-freescale-3rdparty
fatal: repository 'http://git.yoctoproject.org/poky/' not found
Fetching projects:  66% (6/9)  Fetching project fsl-community-bsp-base
Fetching projects:  77% (7/9)  Fetching project meta-freescale
fatal: repository 'http://git.yoctoproject.org/meta-freescale/' not found
error: Cannot fetch meta-freescale
error: Cannot fetch poky
error: Exited sync due to fetch errors
i'm behind a corporate firewall, and from some discussion thread i gather that certain proxy settings and port number are needed to access the git;
Kindly help me regarding the same
I'm also attaching the manifest file
992 次查看
igorpadykov
Hi Satya
please check suggestions for firewall on link
OpenEmbedded
also problems with compulab repositories can be posted on meta-fsl-arm mailing list
meta-freescale Info Page
992 次查看
ecsatya
Thanks igor,
my query was about repo sync of yocto github behind firewall;
best regards
