cl-som-imx8 yocto - NXP BSP source repo sync failure
1,595件の閲覧回数
ecsatya
I need to use the yocto build for cl-som-mx8 board and trying to sync the repo;
i'm following the instructions given @ https://github.com/compulab-yokneam/meta-compulab-imx8/wiki/01.-Build-CompuLab-Images
The repo sync is failing
> repo sync
Fetching project meta-fsl-bsp-release
Fetching project meta-openembedded
Fetching project meta-qt5
Fetching projects:  22% (2/9)  Fetching project meta-browser
Fetching projects:  33% (3/9)  Fetching project meta-freescale-distro
Fetching projects:  44% (4/9)  Fetching project poky
Fetching projects:  55% (5/9)  Fetching project meta-freescale-3rdparty
fatal: repository 'http://git.yoctoproject.org/poky/' not found
Fetching projects:  66% (6/9)  Fetching project fsl-community-bsp-base
Fetching projects:  77% (7/9)  Fetching project meta-freescale
fatal: repository 'http://git.yoctoproject.org/meta-freescale/' not found
error: Cannot fetch meta-freescale
error: Cannot fetch poky
error: Exited sync due to fetch errors
i'm behind a corporate firewall, and from some discussion thread i gather that certain proxy settings and port number are needed to access the git;
Kindly help me regarding the same
I'm also attaching the manifest file
2 返答(返信)
965件の閲覧回数
igorpadykov
Hi Satya
please check suggestions for firewall on link
OpenEmbedded
also problems with compulab repositories can be posted on meta-fsl-arm mailing list
meta-freescale Info Page
965件の閲覧回数
ecsatya
Thanks igor,
my query was about repo sync of yocto github behind firewall;
best regards
