cfimager-imx error -2
838件の閲覧回数
norishinozaki
Contributor V
Hello Champs,
I'm using OBDS(imx50_obds_release_v1_0.tar.gz) for i.MX50.
I built a bin file and when I try to write it to SD-card formatted in FAT32, I got this error:
cfimager-imx.exe -o 0  -f ./output/mx50/bin/diag-obds-mx50ref-rev3.bin -d e:
Error: error -23
What is error -23 ?
Nori Shinozaki
4 返答(返信)
634件の閲覧回数
Yuri
Please try to clear the SD using Linux command  dd, as shown below (an example)
$ sudo dd if=/dev/zero of=/dev/sda bs=512 count=1000
Yuri
634件の閲覧回数
norishinozaki
Contributor V
Hello Yuri,
I didt that but I got the same result error -23.
I erased the SD-card with the "dd" command in Linux then, formatted in FAT32 in Windows.
You meant to use elftosb to write the bin file also in Linux?
No way to use cfimager-imx.exe?
Because my customer is using Cygwin and arm-none-eabi-gcc for Windows.
They can build the OBDS in Windows so they would like to write in Windows.
Nori Shinozaki
634件の閲覧回数
Yuri
  You wrote "I erased the SD-card with the "dd" command in Linux then,
formatted in FAT32 in Windows.". Please try do not format (FAT32) under
Windows.
Yuri.
634件の閲覧回数
norishinozaki
Contributor V
Hello Yuri,
I tried my SD-card without formatted but it results the same -23 error.
Then I tried without SD-to-USB converter, directly insert the SD-card into PC's SD slot.
It worked!
Thanks!
Nori Shinozaki
