burn fuses
burn fuses
sapirbuz
How can we burn the fuses without an external flash on our board?
Can we use the internal ROM to do it?
JorgeCas
On the i.MX8 and i.MX8x families the OTP memory is part of the security subsystem and is controlled by the SCU and SECO only. Please refer to this blog post about how users can read and write eFuses.
Understanding how to burn eFuses on i.MX8 and i.MX8x families.
Best regards.
sapirbuz
Sorry, but i still don't understand if it is possible to burn fuses without an external flash, and how to do it in case it is possible
JorgeCas
Yes, you can burn fuses internally using U-boot, once the board is flashed you can use U-boot commands to read/write efuses using the SCFW API functions that are specified on the blog that is on the past answer.
Best regards.
sapirbuz
What do you mean by "when the board is flashed"?
JorgeCas
It means that you have an image flashed on the board and it is able to boot.
Best regards.
sapirbuz
If I have an image flashed on the board, it means that I have an external flash on the board, right?
But the external flash wasn't enabled (because we need to burn the fuses first) so it is like we don't have an external flash on the board.
How can we burn the fuses without an external flash on our board and we don't have an image flashed on the board?
JorgeCas
Got it, it that case it is not possible, you need to flash the MPU to burn efuses.
Best regards.
sapirbuz
You are wrong.
It is possible using the LPSPI NOR/EEPROM.
After setting the "Boot Device" to "LPSPI NOR/EEPROM" , we succeed to burn the fuses.
