building libusb-1.0.8 errors on imx6
2,357件の閲覧回数
pisces
we need the libusb so file on our IMX.6 platform.
but when we set the acroos complier and try to configure and build.
it report errors as below:
Assembler messages:
Fatal error: invalid -march= option: `armv5t'
configure:3249: $? = 1
before building, we set the environemnt as below:
export PATH=/home/frank/toolchain/bin:$PATH
export CC=arm-fslc-linux-gnueabi-gcc AR=arm-fslc-linux-gnueabi-ar LD=arm-fslc-linux-gnueabi-ld STRIP=arm-fslc-linux-gnueabi-strip
Can anyone help me regarding this?
the attached doc file is the instructions i got from the vendor.
to make the sec1110 smart card chip run, we need to build some libs running on ARM platform.
any suggestiongs will  be highly appreciated.
thanks.
タグ(1)
2,348件の閲覧回数
Bio_TICFSL
Hello weigang,
The i.mx6 is armv7 can not compile by Armv5, that the reason you might have this error.
