basic approach for LED interface with GPIO pins.
1,755件の閲覧回数
anamikalal
Hi all,
I am a newbie in device driver stuffs. I want to connect LEDs to the gpio pins of imx6qdl and use it for debugging purpose.
For that purpose I have modified the device tree as follows:
leds {
            pinctrl-names ="default";
             pinctrl-0 =<&pinctrl_leds>;
compatible = "gpio-leds";
debug-led-1 {
                                label ="Debug-led1";
                                gpios = <&gpio1 1>;
                                linux,default-trigger ="heartbeat";
                                linux,default-state ="on";
                debug-led-2 {
                                label ="Debug-led2";
                                gpios= <&gpio1 2>;
the pinctrl settings are:-
pinctrl_leds: ledsgrp {
                                fsl,pins = <
                                                MX6QDL_PAD_GPIO_1__GPIO1_IO01      0x0b0b0                                /*Debug-led-1*/
                                                MX6QDL_PAD_GPIO_2__GPIO1_IO02       0x0b0b0                                /*Debug-led-2 */
Now I want to know what else I need to do for configuring the gpio pins?
Do I need to modify the board setup code?
Do I need to add/modify something in device driver (leds-gpio.c)code? (eg: platform_device or platform_data structure or the device tree will take care of it?)
Please help !!!
Anamika
ラベル(3)
タグ(1)
709件の閲覧回数
CarlosCasillas
Hi Anamika,
The following threads may be useful for you:
imx6sl evk debug led
Re: Re: GPIO interrupt on i.MX6
Re: Proper GPIO interrupt handling in iMX6
Hope this will be useful for you.
Best regards!
/Carlos
