Hello,everybody.
I want to bake the image.When I run the command ' bitbake fsl-image-gui'.I meet the error below.How can I do?
i@ubuntu:~/bin/build$ bitbake fsl-image-gui
WARNING: Failed to fetch URL http://gpe.linuxtogo.org/download/source/xserver-common-1.34.tar.gz, attempting MIRRORS if available
ERROR: Fetcher failure: Fetch command failed with exit code 4, no output
ERROR: Function failed: Fetcher failure for URL: 'http://gpe.linuxtogo.org/download/source/xserver-common-1.34.tar.gz'. Unable to fetch URL from any source.
ERROR: Logfile of failure stored in: /home/carmili/bin/build/tmp/work/all-poky-linux/xserver-common/1.34-r8/temp/log.do_fetch.14738
ERROR: Task 6034 (/home/carmili/bin/sources/meta-openembedded/meta-oe/recipes-graphics/xserver-common/xserver-common_1.34.bb, do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 3585 tasks of which 3532 didn't need to be rerun and 1 failed.
Waiting for 0 running tasks to finish:
Summary: 1 task failed:
Summary: There were 2 WARNING messages shown.
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
Thank you.
解決済! 解決策の投稿を見る。
You can try this inside the DL_DIR folder (if you do not set it, it is on the BASE folder)
$ wget http://www.mlbassoc.com/misc/xserver-common-1.34.tar.gz -O xserver-common-1.34.tar.gz
$ > xserver-common-1.34.tar.gz.done
Then bake.
Then bake.
Thank you very much.
Camille,
I've seen this too and I believe you got an answer on meta-freescale and have this resolved now. You can set a common downloads setting in local.conf using DL_DIR=<path> and all your downloads can be in one location.
My understanding is that this location for downloading xserver is flaky for downloads and periodically goes down. I'll push them to get another mirror of this up. If nothing happens we'll create an update to pull this from another location.
