camera and display interface do not exist in my imx6ull board,but ip camera may be used.
1. can i disable the reserved-memory(cma) node in imx6ull dts? if yes, is there any bad effect?
2. which driver may use that CMA area?
已解决! 转到解答。
I considered with collegues and it is not good idea to disable CMA.
Many peripherals on i.MX6ULL used DMA and needs CMA.
Of course you can change their drivers for not using DMA but then you loose the performance.
